Is my radio supposed to electrocute me?
Thanks guys, I'll take the screw out of the Bakelite this evening and see what happens.
And lesson learned, one hand from now on.
"He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
RE: Is my radio supposed to electrocute me? - by Greenhorn - 10-17-2016, 05:09 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8338 online users. [Complete List]
» 3 Member(s) | 8335 Guest(s)
