What Philco is This?
(10-14-2016, 05:30 PM)markmokris Wrote:
(10-14-2016, 04:07 PM)Paul Philco322 Wrote:  Is that button on the upper left some kind of add on?
Good  luck with it.
Yeah it definitely is Paul.  It is a little rotary switch connected to nothing.  I am going to try a save the cabinet.  I don't think it is a candidate for a refinish.  So I'll probably leave the switch in place.
Mark K8KZ
 There isn't realy any original finish to save, the dark walnut shaded lacquer on the top and sides is gone, and the lacquer on the front panel is sun baked on top of having that useless switch, you might as well strip it and start again.
What Philco is This? - by markmokris - 10-14-2016, 03:37 PM
RE: What Philco is This? - by markmokris - 10-14-2016, 04:01 PM
RE: What Philco is This? - by Ron Ramirez - 10-15-2016, 07:59 AM
RE: What Philco is This? - by Paul Philco322 - 10-14-2016, 04:07 PM
RE: What Philco is This? - by markmokris - 10-14-2016, 05:30 PM
RE: What Philco is This? - by Arran - 10-18-2016, 03:17 AM
RE: What Philco is This? - by morzh - 10-14-2016, 04:31 PM
RE: What Philco is This? - by PhilcoPhan1936 - 10-14-2016, 06:23 PM
RE: What Philco is This? - by markmokris - 10-14-2016, 10:57 PM
RE: What Philco is This? - by PhilcoPhan1936 - 10-15-2016, 02:45 AM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4795 online users. [Complete List]
» 3 Member(s) | 4792 Guest(s)
