Philco 610 Volume Control Taper
(10-17-2016, 03:39 PM)Radioroslyn Wrote:  Guess #2 is that an audio tapper volume control makes the set sound like it can play really loud as most of the gain is in the beginning of the rotation. Personally I think it's marketing trick to give a buyer the impression that a given set has a lot of volume when it doesn't.
Terry,
I think you are right.
At this point, I believe the more modern volume control that I used as a replacement has a bit more advanced slope than the older control I replaced.  I wired in the old control again to evaluate the difference.  I believe that they are both audio taper.
The older control advances the volume pretty quickly,  just not as quickly as the newer control.  So I am chalking it up to a difference between the controls in the first 50% of the audio taper curve.
The only reason I replaced the vintage control (It is not an original Philco part) was because the shaft was goofy.  It had flatness on both sides, and I couldn't get the Philco knob to grip.  I figured out a way to make the knob work, so I put the vintage control back in.  It works better.
Mark K8KZ
Philco 610 Volume Control Taper - by markmokris - 10-16-2016, 07:56 PM
RE: Philco 610 Volume Control Taper - by morzh - 10-16-2016, 08:40 PM
RE: Philco 610 Volume Control Taper - by morzh - 10-17-2016, 10:31 AM
RE: Philco 610 Volume Control Taper - by markmokris - 10-18-2016, 08:41 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 2684 online users. [Complete List]
» 2 Member(s) | 2682 Guest(s)
