Philco 38-5X
I am working on a 38-5.  The first thing I did was to measure the power transformer resistances.  They all were about 50% high.  The number on the transformer is not the ono of the options listed for a 38-5.  The one I have is a part number 32-7598N with what appears to be a date code of 8-37.  Is that an acceptable replacement?  What should the impedance read?
TerryMSU
Philco 38-5 initial inspection - by TerryMSU - 10-13-2016, 09:10 PM
RE: Philco 38-5 initial inspection - by Arran - 10-14-2016, 04:30 AM
RE: Philco 38-5X - by TerryMSU - 10-20-2016, 12:04 PM
RE: Philco 38-5X - by Radioroslyn - 10-20-2016, 01:17 PM
RE: Philco 38-5 initial inspection - by TerryMSU - 10-13-2016, 10:24 PM
RE: Philco 38-5 initial inspection - by Arran - 10-14-2016, 04:48 AM
RE: Philco 38-5 initial inspection - by morzh - 10-14-2016, 09:47 AM
RE: Philco 38-5X - by Ron Ramirez - 10-19-2016, 06:54 PM
RE: Philco 38-5X - by Ron Ramirez - 10-19-2016, 06:58 PM
RE: Philco 38-5X - by Ron Ramirez - 10-20-2016, 01:29 PM
Philco 38-5X How to remove the Shadowmeter? - by TerryMSU - 10-18-2016, 09:28 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8723 online users. [Complete List]
» 3 Member(s) | 8720 Guest(s)
