Philco 38-5X
Terry,
I have never worked on a shadow meter so can't help much but here is some shadow meter info that may be useful on Chuck's site; http://www.philcorepairbench.com/tips/svctip01.htm
Philco 38-5 initial inspection - by TerryMSU - 10-13-2016, 09:10 PM
RE: Philco 38-5 initial inspection - by Arran - 10-14-2016, 04:30 AM
RE: Philco 38-5X - by TerryMSU - 10-20-2016, 12:04 PM
RE: Philco 38-5X - by Radioroslyn - 10-20-2016, 01:17 PM
RE: Philco 38-5 initial inspection - by TerryMSU - 10-13-2016, 10:24 PM
RE: Philco 38-5 initial inspection - by Arran - 10-14-2016, 04:48 AM
RE: Philco 38-5 initial inspection - by morzh - 10-14-2016, 09:47 AM
RE: Philco 38-5X - by Ron Ramirez - 10-19-2016, 06:54 PM
RE: Philco 38-5X - by Ron Ramirez - 10-19-2016, 06:58 PM
RE: Philco 38-5X - by Ron Ramirez - 10-20-2016, 01:29 PM
RE: Philco 38-5X How to remove the Shadowmeter? - by klondike98 - 10-19-2016, 12:38 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6890 online users. [Complete List]
» 3 Member(s) | 6887 Guest(s)
