10 radio cabinet restoration chronicles
#46
Mine is an honest opinion; then again, since I know squat about cabinetry, it's only worth so much. Icon_lol
RE: 10 radio cabinet restoration chronicles - by morzh - 10-19-2016, 02:32 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6641 online users. [Complete List]
» 1 Member(s) | 6640 Guest(s)
