Philco 38-5X
Got it! Two spring wire clips were not visible, but easy to remove. Plus the shadow meter works, although it may be a little low in sensitivity.
Next question... how to remove the escutcheon on this radio?
TerryMSU
Philco 38-5 initial inspection - by TerryMSU - 10-13-2016, 09:10 PM
RE: Philco 38-5 initial inspection - by Arran - 10-14-2016, 04:30 AM
RE: Philco 38-5X - by TerryMSU - 10-20-2016, 12:04 PM
RE: Philco 38-5X - by Radioroslyn - 10-20-2016, 01:17 PM
RE: Philco 38-5 initial inspection - by TerryMSU - 10-13-2016, 10:24 PM
RE: Philco 38-5 initial inspection - by Arran - 10-14-2016, 04:48 AM
RE: Philco 38-5 initial inspection - by morzh - 10-14-2016, 09:47 AM
RE: Philco 38-5X - by Ron Ramirez - 10-19-2016, 06:54 PM
RE: Philco 38-5X - by Ron Ramirez - 10-19-2016, 06:58 PM
RE: Philco 38-5X - by Ron Ramirez - 10-20-2016, 01:29 PM
RE: Philco 38-5X How to remove the Shadowmeter? - by TerryMSU - 10-19-2016, 05:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8148 online users. [Complete List]
» 3 Member(s) | 8145 Guest(s)
