Philco 38-5 veneer issues, what is this wood?
As I look this cabinet over, it appears that it was largely assembled with screws and glue. Is that correct? I am considering trying to disassemble the cabinet to deal with the veneer issues. Am I insane? Your input is gratefully requested. If I do so, I think I can reglue the veneer to the side columns. Has anyone ever tried anything like this? That seems to be the only way I can get a good fit and a good glue job on the veneer.
TerryMSU
RE: Philco 38-5 with veneer issues - by TerryMSU - 10-13-2016, 08:45 AM
RE: Philco 38-5 with veneer issues - by TerryMSU - 10-13-2016, 06:11 PM
RE: Philco 38-5 veneer issues, disassemble cabinet? - by TerryMSU - 10-19-2016, 08:36 PM
Philco 91 Tuning Condenser
There are currently 8623 online users. [Complete List]
» 2 Member(s) | 8621 Guest(s)
