Philco 38-5X
Renovated Radios sells the proper mounts. They are the same as used on the 38-4, and the very rare 38-250EZ. At work so no time to look up the part number for you, sorry. Go to Ed's website and you can find them.
http://www.renovatedradios.com/
Philco 38-5 initial inspection - by TerryMSU - 10-13-2016, 09:10 PM
RE: Philco 38-5 initial inspection - by Arran - 10-14-2016, 04:30 AM
RE: Philco 38-5X - by TerryMSU - 10-20-2016, 12:04 PM
RE: Philco 38-5X - by Radioroslyn - 10-20-2016, 01:17 PM
RE: Philco 38-5 initial inspection - by TerryMSU - 10-13-2016, 10:24 PM
RE: Philco 38-5 initial inspection - by Arran - 10-14-2016, 04:48 AM
RE: Philco 38-5 initial inspection - by morzh - 10-14-2016, 09:47 AM
RE: Philco 38-5X - by Ron Ramirez - 10-19-2016, 06:54 PM
RE: Philco 38-5X - by Ron Ramirez - 10-19-2016, 06:58 PM
RE: Philco 38-5X - by Ron Ramirez - 10-20-2016, 01:29 PM
There are currently 3688 online users. [Complete List]
» 3 Member(s) | 3685 Guest(s)
