Philco 38-5 veneer issues, what is this wood?
You should be able to purchase it at any hardware store or home improvement center. I think it's better than Elmer's Carpenters Wood Glue.
RE: Philco 38-5 with veneer issues - by TerryMSU - 10-13-2016, 08:45 AM
RE: Philco 38-5 with veneer issues - by TerryMSU - 10-13-2016, 06:11 PM
RE: Philco 38-5 veneer issues, disassemble cabinet? - by Ron Ramirez - 10-20-2016, 06:57 PM
Philco 91 Tuning Condenser
There are currently 8760 online users. [Complete List]
» 2 Member(s) | 8758 Guest(s)
