RCA 10K Restoration Journal
Thanks for all of the valuable input.
I think I'll be staring at the transformer for a while until I get the nerve to make a decision. I've used shrink wrap in the past of the exposed wires with brittle, fractured insulation and it's worked well. But, its the things I can't see that have got me bothered. You know it's got to be a hostile environment inside the case of the transformer than outside in the chassis. I must give this careful consideration. I could make matters worse than the need be.
I bought one of those do it all no name meters because it autoscales and for about 15 bucks it's a deal for doing quick checks. The capacitance does float around quite a bit sometimes.
I thinks I'll get some resistors and a .010 mf cap and play a bit tomorrow.
I've also got an older Fluke that I trust when I believe I have to make an accurate measurement but it doesn't give a read out on capacitance. When I need to make a measurement and consider it as the standard, that's the meter I use. The old Hickock meter has been turned on yet. Might be interesting to get distracted looking at it's innards until my radio parts arrive. It has a capacitance setting as well but I don't want to start out by plugging it in as seeing what happens next.
RCA 10K Restoration Journal - by g8wayg8r - 07-26-2009, 11:28 PM
Re: RCA 10K Restoration Journal - by jayoungs - 07-27-2009, 10:24 AM
Re: RCA 10K Restoration Journal - by exray - 07-27-2009, 07:02 PM
Re: RCA 10K Restoration Journal - by Dave D - 07-27-2009, 11:58 PM
Re: RCA 10K Restoration Journal - by g8wayg8r - 08-04-2009, 01:27 AM
Re: RCA 10K Restoration Journal - by g8wayg8r - 08-22-2009, 12:56 AM
Re: RCA 10K Restoration Journal - by g8wayg8r - 08-23-2009, 12:51 PM
Re: RCA 10K Restoration Journal - by exray - 08-23-2009, 01:29 PM
Re: RCA 10K Restoration Journal - by g8wayg8r - 08-30-2009, 06:10 PM
Re: RCA 10K Restoration Journal - by codefox1 - 08-30-2009, 06:54 PM
Re: RCA 10K Restoration Journal - by exray - 08-30-2009, 08:50 PM
Re: RCA 10K Restoration Journal - by g8wayg8r - 08-30-2009, 09:31 PM
Re: RCA 10K Restoration Journal - by exray - 08-30-2009, 10:44 PM
Re: RCA 10K Restoration Journal - by g8wayg8r - 09-13-2009, 06:05 PM
Re: RCA 10K Restoration Journal - by g8wayg8r - 09-13-2009, 10:50 PM
Re: RCA 10K Restoration Journal - by g8wayg8r - 09-20-2009, 11:38 PM
Re: RCA 10K Restoration Journal - by g8wayg8r - 09-30-2009, 11:52 PM
Re: RCA 10K Restoration Journal - by g8wayg8r - 11-19-2009, 02:06 AM
Philco 91 Tuning Condenser
There are currently 9751 online users. [Complete List]
» 1 Member(s) | 9750 Guest(s)
