Philco 38-5 veneer issues, what is this wood?
i am now seriously considering either finding a cabinet from a donor or else using peel-and-stick veneer.  If I go with veneer, does anyone know what the wood is on the pilasters?  I have heard either mahogany or else walnut, from so called experts at the fine woodworking shops.
RE: Philco 38-5 with veneer issues - by TerryMSU - 10-13-2016, 08:45 AM
RE: Philco 38-5 with veneer issues - by TerryMSU - 10-13-2016, 06:11 PM
RE: Philco 38-5 veneer issues, disassemble cabinet? - by TerryMSU - 10-22-2016, 08:06 PM
Philco 91 Tuning Condenser
There are currently 9058 online users. [Complete List]
» 2 Member(s) | 9056 Guest(s)
