Philco 37-610T Bullet Restoration
Video 6 in my series of restoring my Philco 37-610T "Bullet" radio. Towards the end, I make an unfortunate discovery.
[Video: https://youtu.be/dsJ35RpAYyc]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
RE: Philco 37-610T Bullet Restoration - by PhilcoPhan1936 - 10-24-2016, 08:54 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6327 online users. [Complete List]
» 3 Member(s) | 6324 Guest(s)
