Philco 37-610T Bullet Restoration
Any philco w/a single 47,42, or 6F6 will work fine as a replacement.
RE: Philco 37-610T Bullet Restoration - by Radioroslyn - 10-24-2016, 09:17 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8775 online users. [Complete List]
» 3 Member(s) | 8772 Guest(s)
