Philco 37-610T Bullet Restoration
Part 7 of the 37-610T chassis restoration. Swapping the speaker, and more of checking the coils.
[Video: https://youtu.be/0PwuYFA2nhU]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
RE: Philco 37-610T Bullet Restoration - by PhilcoPhan1936 - 10-25-2016, 12:06 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7087 online users. [Complete List]
» 3 Member(s) | 7084 Guest(s)
