Philco 37-610T Bullet Restoration
Part 8. Installing the power cord and repairing the dial lamp housing.
[Video: https://youtu.be/IYKNtrDqP3E]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
RE: Philco 37-610T Bullet Restoration - by PhilcoPhan1936 - 10-25-2016, 02:21 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4265 online users. [Complete List]
» 3 Member(s) | 4262 Guest(s)
