subbing eye tubes??
(08-22-2016, 08:15 PM)Dan Walker Wrote:     Thanks for the input. I had a friend of mine build me a voltage doubler and after it was installed
 I used the 1629 eye tube and it works very well.
Hi Dan, Wayne here in Phoenix.  It's been a while since I rewired a 6X6 for a 6G5(6U5) but if I recall correctly, you just interchange the pin 4 and pin 6 wires.  I was up in Calgary for a couple of months this summer but your whole street was blocked off for construction so it kind of deterred me from dropping by.
subbing eye tubes?? - by Dan Walker - 06-04-2016, 10:01 AM
RE: subbing eye tubes?? - by gregb - 06-04-2016, 10:23 AM
RE: subbing eye tubes?? - by Arran - 06-05-2016, 02:15 AM
RE: subbing eye tubes?? - by Dan Walker - 06-05-2016, 09:43 AM
RE: subbing eye tubes?? - by Arran - 06-05-2016, 11:47 PM
RE: subbing eye tubes?? - by Phlogiston - 06-06-2016, 04:16 PM
RE: subbing eye tubes?? - by Arran - 06-08-2016, 06:24 AM
RE: subbing eye tubes?? - by Dan Walker - 08-22-2016, 08:15 PM
RE: subbing eye tubes?? - by radioswede - 10-25-2016, 01:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
