Variable capacitor cleaning
I do it to the whole thing, with the trimmers. Did both washing in dishwasher and soaking in dishwashing liquid, with soft long brush agitation and good tap water rinse.
The latter got me better results - bright shiny cap with no residue. Dishwasher worked fine, but it dulled up the vanes a bit. Plus some powdery light residue that though did not affect much was still an extra that I could do without.
Variable capacitor cleaning - by Paperboy - 10-25-2016, 03:36 PM
RE: Variable capacitor cleaning - by morzh - 10-25-2016, 04:03 PM
RE: Variable capacitor cleaning - by Chris h - 10-26-2016, 08:00 AM
RE: Variable capacitor cleaning - by morzh - 10-26-2016, 08:49 AM
RE: Variable capacitor cleaning - by KCMike - 10-26-2016, 12:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6438 online users. [Complete List]
» 3 Member(s) | 6435 Guest(s)
