Philco 42-355
Larry Bordonaro at Old-Time Replications.
http://www.antiqueradioknobs.com/
If you do not have your old escutcheon, you will have to come up with the brass insert above the knobs that reads VOLUME, BASS, TREBLE, TUNING. Otherwise you can remove the old insert from your old escutcheon and install on the repro.
Larry's repro escutcheon will be better then new overall, and looks just like the originals - but without the shrinkage, cracks and breaks!
Philco 42-355 - by Guest - 09-02-2009, 10:57 AM
Re: Philco 42-355 - by Ron Ramirez - 09-02-2009, 01:00 PM
Re: Philco 42-355 - by Raleigh - 09-06-2009, 08:17 PM
