Philco 37-610T Bullet Restoration
Part 9 of the chassis restoration. Getting closer!
[Video: https://youtu.be/UmM2YTs4Uas]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
RE: Philco 37-610T Bullet Restoration - by PhilcoPhan1936 - 10-27-2016, 03:49 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8786 online users. [Complete List]
» 3 Member(s) | 8783 Guest(s)
