42-321 Questions
Unless it is all broken up and threatens the whole radio integrity, there is no harm in leaving it alone. If a cap is a paper one and is leaky....could be removed. I think either way it does not affect the operation much.
RE: 42-321 Questions - by klondike98 - 10-27-2016, 08:55 AM
RE: 42-321 Questions - by Paperboy - 10-27-2016, 03:31 PM
RE: 42-321 Questions - by morzh - 10-27-2016, 04:33 PM
RE: 42-321 Questions - by Radioroslyn - 10-27-2016, 04:35 PM
RE: 42-321 Questions - by morzh - 10-27-2016, 06:14 PM
RE: 42-321 Questions - by Paperboy - 10-28-2016, 10:19 AM
RE: 42-321 Questions - by Radioroslyn - 10-28-2016, 04:29 PM
RE: 42-321 Questions - by Paperboy - 10-28-2016, 11:02 PM
RE: 42-321 Questions - by Radioroslyn - 10-28-2016, 11:38 PM
RE: 42-321 Questions - by Paperboy - 10-29-2016, 09:28 AM
RE: 42-321 Questions - by Radioroslyn - 10-29-2016, 10:16 AM
RE: 42-321 Questions - by Paperboy - 11-04-2016, 11:39 AM
42-321 philco paper behind dial - by Paperboy - 10-27-2016, 08:38 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7816 online users. [Complete List]
» 3 Member(s) | 7813 Guest(s)
