37-610 "Bullet" Cabinet refinish
And here's a "studio shot" of the for-now-finished radio.
[Image: https://farm5.staticflickr.com/4280/3587...d259_b.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
RE: 37-610 "Bullet" Cabinet refinish - by PhilcoPhan1936 - 10-28-2016, 01:03 AM
Philco 91 Tuning Condenser
There are currently 10169 online users. [Complete List]
» 2 Member(s) | 10167 Guest(s)
