41-280, -286, -287, -290 1st IF Xfmr
Joe
If I didn't have my EDM xmtr and a dedicated laptop playing a rotation of almost 900 easy listening/mood music tunes, my FM receivers would also be useless. All I can pick up around here is about 70% country crap and 30% rock - or, I should say, what passes for "rock" these days. Jazz? Nonexistent around here. One Mexican station. A few college stations; one or two play classical music sometimes. There is a classical station in Louisville but I am outside their coverage area; therefore I can only receive them on the one receiver connected to an attic antenna.
RE: 41-280, -286, -287, -290 1st IF Xfmr - by Ron Ramirez - 10-28-2016, 11:20 PM
Restoring Philco 96
There are currently 7719 online users. [Complete List]
» 3 Member(s) | 7716 Guest(s)
