Ron's 2016 Cabinet Work Part III: 38-624T
After sanding...and sanding...and sanding...until my thumb was bleeding...
[Image: http://www.philcoradio.com/images/phorum/37610_005.jpg]
Not perfect, but it looks better than it did with the damaged spot.
more to come...
RE: Ron's 2016 Cabinet Work Part III: 37-610T V2 - by Ron Ramirez - 10-29-2016, 12:12 PM
There are currently 9224 online users. [Complete List]
» 2 Member(s) | 9222 Guest(s)
