Update on 38-5 restoration, Almost ready for cabinet!
Ron,
Everything you say makes sense except for face down. I will be surprised if Fedex or UPS will keep it in the same orientation. Am I missing something?
Also, would bubble pack work as well for packing and fill?
Thanks again,
TerryMSU
RE: Question on philco 38-5 restoration - by TerryMSU - 10-29-2016, 09:20 PM
Users browsing this thread: 16 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 9094 online users. [Complete List]
» 3 Member(s) | 9091 Guest(s)
