Update on 38-5 restoration, Almost ready for cabinet!
I am actually considering asking him to double box it, one box inside the other, with suitable padding between the boxes. Is that overkill?
RE: Question on philco 38-5 restoration - by TerryMSU - 10-29-2016, 09:45 PM
Users browsing this thread: 15 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8693 online users. [Complete List]
» 3 Member(s) | 8690 Guest(s)
