Ron's 2016 Cabinet Work Part III: 38-624T
Ron did you spray sanding sealer or clear lacquer? If sanding sealer, do you sand before using grain filler?
Coming along nicely.
RE: Ron's 2016 Cabinet Work Part III: 38-624T - by KCMike - 10-30-2016, 07:54 AM
There are currently 9152 online users. [Complete List]
» 2 Member(s) | 9150 Guest(s)
