Update on 38-5 restoration, Almost ready for cabinet!
Yabbut...
...the field dissipates the heat more efficiently than does the resistor. I'm no expert on this as I am not an engineer, but I can tell you from practical experience that a speaker field seldom gets so hot that you can't touch it. This is not true for a resistor being used as a replacement for a field coil.
Since we've gone in an electronic restoration angle, I've moved this thread to Philco Electronic Restoration.
RE: Question on philco 38-5 restoration - by Ron Ramirez - 10-30-2016, 12:02 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4698 online users. [Complete List]
» 2 Member(s) | 4696 Guest(s)
