Philco 84 code 121 no sound
I put a portable radio near the 77 tubes. The portable was set at 1460 and the radio approximately at 1000kc. There was more of a squeal than a hum and that changed with the position of the portable radio's antenna. Should I be trying with a signal generator? and at what point?
Philco 84 code 121 no sound - by Mike L - 10-24-2016, 06:55 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-24-2016, 08:14 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-25-2016, 07:34 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-25-2016, 08:07 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-29-2016, 10:42 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-29-2016, 11:19 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-29-2016, 11:50 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 12:27 AM
RE: Philco 84 code 121 no sound - by Mike L - 10-30-2016, 09:46 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 11:07 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 02:15 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-30-2016, 04:11 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 04:55 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-30-2016, 06:32 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 07:51 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-31-2016, 07:31 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-31-2016, 08:23 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-01-2016, 07:46 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-01-2016, 10:15 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-02-2016, 07:25 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-02-2016, 08:34 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-02-2016, 09:07 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-02-2016, 09:17 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-03-2016, 08:08 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-03-2016, 08:34 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-09-2016, 02:22 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-09-2016, 11:44 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-10-2016, 12:05 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-11-2016, 03:52 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-11-2016, 03:59 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-11-2016, 07:13 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-11-2016, 07:21 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-11-2016, 07:29 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 12:04 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-13-2016, 12:34 AM
RE: Philco 84 code 121 no sound - by klondike98 - 11-13-2016, 08:56 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 09:45 AM
RE: Philco 84 code 121 no sound - by klondike98 - 11-13-2016, 09:48 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 12:01 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-13-2016, 03:53 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 08:20 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-14-2016, 12:35 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-14-2016, 08:40 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-14-2016, 09:47 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-14-2016, 10:25 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-15-2016, 01:04 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-19-2016, 04:27 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-19-2016, 11:28 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-20-2016, 11:16 AM
RE: Philco 84 code 121 no sound - by KCMike - 11-20-2016, 11:36 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 11:44 AM
RE: Philco 84 code 121 no sound - by morzh - 11-20-2016, 11:49 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 11:57 AM
RE: Philco 84 code 121 no sound - by morzh - 11-20-2016, 12:01 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 12:12 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-20-2016, 01:54 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 07:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7446 online users. [Complete List]
» 3 Member(s) | 7443 Guest(s)
