Hi-Fi tube amp kit from China
I finally had a chance to get the transformers, binding posts, power switch and input connectors put on.
I did learn (the hard way) Icon_neutral  not to over tighten the nuts on the speaker binding posts...
Had to order a set. Oh well..
A couple Q's:
1. This power transformer has 2 primary windings, each at 110v. I assume you connect in parallel for our 120v line? I never got an answer from support when I inquired. Don't know if I should use only one, or both - looks like I connect in series for the 220v.
2. This does not have any line safety caps. Should I add a set of those?
3. There is a green/yellow wire that I assume is ground from the transformer, but it doesn't have continuity to any other lead or even the mounting bolts.
Tim
Hi-Fi tube amp kit from China - by TV MAN - 10-12-2016, 10:38 PM
RE: Hi-Fi tube amp kit from China - by morzh - 10-13-2016, 08:48 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 10-24-2016, 10:21 PM
RE: Hi-Fi tube amp kit from China - by morzh - 10-24-2016, 10:29 PM
RE: Hi-Fi tube amp kit from China - by KCMike - 10-24-2016, 10:48 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 10-26-2016, 09:40 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 10-31-2016, 09:17 PM
RE: Hi-Fi tube amp kit from China - by morzh - 10-31-2016, 10:49 PM
RE: Hi-Fi tube amp kit from China - by BrendaAnnD - 02-04-2017, 10:12 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 11-03-2016, 10:01 AM
RE: Hi-Fi tube amp kit from China - by morzh - 11-04-2016, 10:10 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 11-18-2016, 09:23 PM
RE: Hi-Fi tube amp kit from China - by radiohenry - 11-19-2016, 09:45 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 12-17-2016, 11:51 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 12-17-2016, 12:45 PM
RE: Hi-Fi tube amp kit from China - by morzh - 12-17-2016, 02:26 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 12-18-2016, 10:05 PM
RE: Hi-Fi tube amp kit from China - by morzh - 12-18-2016, 10:56 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 12-20-2016, 12:46 PM
RE: Hi-Fi tube amp kit from China - by morzh - 12-20-2016, 12:56 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-16-2017, 10:58 PM
RE: Hi-Fi tube amp kit from China - by morzh - 01-17-2017, 09:10 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-17-2017, 08:16 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-17-2017, 08:21 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-18-2017, 11:55 PM
RE: Hi-Fi tube amp kit from China - by morzh - 01-19-2017, 09:03 AM
RE: Hi-Fi tube amp kit from China - by PhilcoMike - 01-19-2017, 03:33 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-20-2017, 12:14 AM
RE: Hi-Fi tube amp kit from China - by morzh - 01-20-2017, 12:48 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-20-2017, 06:03 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-20-2017, 09:36 PM
RE: Hi-Fi tube amp kit from China - by Mondial - 01-20-2017, 09:58 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-21-2017, 12:48 AM
RE: Hi-Fi tube amp kit from China - by morzh - 01-21-2017, 12:38 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-22-2017, 12:43 AM
RE: Hi-Fi tube amp kit from China - by Arran - 01-23-2017, 05:50 AM
RE: Hi-Fi tube amp kit from China - by Mondial - 01-23-2017, 08:52 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-26-2017, 10:41 PM
RE: Hi-Fi tube amp kit from China - by Eliot Ness - 01-27-2017, 09:13 AM
RE: Hi-Fi tube amp kit from China - by morzh - 01-27-2017, 02:42 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-29-2017, 02:13 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 01-29-2017, 02:21 AM
RE: Hi-Fi tube amp kit from China - by morzh - 01-29-2017, 03:46 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 02-04-2017, 12:26 PM
RE: Hi-Fi tube amp kit from China - by gregb - 02-04-2017, 01:51 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 02-04-2017, 02:38 PM
RE: Hi-Fi tube amp kit from China - by morzh - 02-04-2017, 09:07 PM
RE: Hi-Fi tube amp kit from China - by gregb - 02-04-2017, 09:28 PM
RE: Hi-Fi tube amp kit from China - by morzh - 02-04-2017, 09:55 PM
RE: Hi-Fi tube amp kit from China - by BrendaAnnD - 02-04-2017, 10:46 PM
RE: Hi-Fi tube amp kit from China - by morzh - 02-04-2017, 11:38 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 02-04-2017, 11:51 PM
RE: Hi-Fi tube amp kit from China - by morzh - 02-04-2017, 11:56 PM
RE: Hi-Fi tube amp kit from China - by gregb - 02-05-2017, 12:04 AM
RE: Hi-Fi tube amp kit from China - by Mondial - 02-05-2017, 12:14 AM
RE: Hi-Fi tube amp kit from China - by morzh - 02-05-2017, 12:37 AM
RE: Hi-Fi tube amp kit from China - by gregb - 02-05-2017, 12:56 AM
RE: Hi-Fi tube amp kit from China - by gregb - 02-05-2017, 12:59 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 02-05-2017, 01:19 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 03-11-2017, 01:22 AM
RE: Hi-Fi tube amp kit from China - by morzh - 03-11-2017, 11:00 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 03-11-2017, 12:40 PM
RE: Hi-Fi tube amp kit from China - by BrendaAnnD - 03-23-2017, 11:12 AM
RE: Hi-Fi tube amp kit from China - by morzh - 03-11-2017, 06:36 PM
RE: Hi-Fi tube amp kit from China - by Arran - 03-22-2017, 04:02 AM
RE: Hi-Fi tube amp kit from China - by morzh - 03-22-2017, 09:30 AM
RE: Hi-Fi tube amp kit from China - by BrendaAnnD - 03-22-2017, 09:52 AM
RE: Hi-Fi tube amp kit from China - by Arran - 03-22-2017, 12:31 PM
RE: Hi-Fi tube amp kit from China - by morzh - 03-22-2017, 01:38 PM
RE: Hi-Fi tube amp kit from China - by BrendaAnnD - 03-23-2017, 05:56 AM
RE: Hi-Fi tube amp kit from China - by morzh - 03-23-2017, 08:30 AM
RE: Hi-Fi tube amp kit from China - by BrendaAnnD - 03-23-2017, 10:55 AM
RE: Hi-Fi tube amp kit from China - by Arran - 03-23-2017, 08:04 PM
RE: Hi-Fi tube amp kit from China - by BrendaAnnD - 03-26-2017, 10:01 AM
RE: Hi-Fi tube amp kit from China - by morzh - 03-26-2017, 11:33 AM
RE: Hi-Fi tube amp kit from China - by BrendaAnnD - 03-26-2017, 11:45 AM
RE: Hi-Fi tube amp kit from China - by Mondial - 03-26-2017, 01:24 PM
RE: Hi-Fi tube amp kit from China - by morzh - 03-26-2017, 03:23 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 03-27-2017, 10:38 AM
RE: Hi-Fi tube amp kit from China - by TV MAN - 04-11-2017, 10:35 PM
RE: Hi-Fi tube amp kit from China - by TV MAN - 04-20-2017, 11:14 PM
RE: Hi-Fi tube amp kit from China - by morzh - 04-21-2017, 08:08 AM
