Update on 38-5 restoration, Almost ready for cabinet!
Well I finally checked out the speaker and output transformer that I have. The speaker, is of course the wrong size for the tabletop cabinet. I was hoping to use the output transformer, but one side measures about 2 Kohns. The rest appears to be OK. Perhaps I can untapped the transformer and get lucky enough to find an end and touch up the soldering. Otherwise, I will need a transformer as well as the speaker.
TerryMSU
RE: Question on philco 38-5 restoration - by TerryMSU - 11-01-2016, 01:17 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7410 online users. [Complete List]
» 3 Member(s) | 7407 Guest(s)
