Philco 84 code 121 no sound
Yes, that is with the signal generator set at 460 KC. The only sound that was produced was the very faint squeal at those two dial locations, everywhere else was silent. Where am I registering max out put? Volume or do I connect my VTVM somewhere?
Philco 84 code 121 no sound - by Mike L - 10-24-2016, 06:55 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-24-2016, 08:14 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-25-2016, 07:34 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-25-2016, 08:07 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-29-2016, 10:42 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-29-2016, 11:19 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-29-2016, 11:50 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 12:27 AM
RE: Philco 84 code 121 no sound - by Mike L - 10-30-2016, 09:46 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 11:07 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 02:15 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-30-2016, 04:11 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 04:55 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-30-2016, 06:32 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 07:51 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-31-2016, 07:31 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-31-2016, 08:23 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-01-2016, 07:46 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-01-2016, 10:15 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-02-2016, 07:25 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-02-2016, 08:34 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-02-2016, 09:07 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-02-2016, 09:17 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-03-2016, 08:08 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-03-2016, 08:34 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-09-2016, 02:22 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-09-2016, 11:44 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-10-2016, 12:05 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-11-2016, 03:52 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-11-2016, 03:59 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-11-2016, 07:13 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-11-2016, 07:21 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-11-2016, 07:29 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 12:04 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-13-2016, 12:34 AM
RE: Philco 84 code 121 no sound - by klondike98 - 11-13-2016, 08:56 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 09:45 AM
RE: Philco 84 code 121 no sound - by klondike98 - 11-13-2016, 09:48 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 12:01 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-13-2016, 03:53 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 08:20 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-14-2016, 12:35 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-14-2016, 08:40 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-14-2016, 09:47 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-14-2016, 10:25 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-15-2016, 01:04 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-19-2016, 04:27 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-19-2016, 11:28 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-20-2016, 11:16 AM
RE: Philco 84 code 121 no sound - by KCMike - 11-20-2016, 11:36 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 11:44 AM
RE: Philco 84 code 121 no sound - by morzh - 11-20-2016, 11:49 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 11:57 AM
RE: Philco 84 code 121 no sound - by morzh - 11-20-2016, 12:01 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 12:12 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-20-2016, 01:54 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 07:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3823 online users. [Complete List]
» 3 Member(s) | 3820 Guest(s)
