Philco 40-84 case
I don't know that particular model number but i think its safe to say that on a 1940 model that its lacquer. Soapy wet rag works fine for cleaning. Rinse off with a damp rag. Don't 'wet' the cabinet and I'm sure it will come out fine.
Philco 40-84 case - by rjm - 09-05-2009, 05:20 PM
Re: Philco 40-84 case - by exray - 09-05-2009, 10:47 PM
Re: Philco 40-84 case - by rjm - 09-05-2009, 11:09 PM
Re: Philco 40-84 case - by exray - 09-06-2009, 12:24 AM
Re: Philco 40-84 case - by rjm - 09-17-2009, 05:09 PM
Re: Philco 40-84 case - by jayoungs - 09-18-2009, 04:14 PM
Re: Philco 40-84 case - by rjm - 09-18-2009, 04:47 PM
Re: Philco 40-84 case - by codefox1 - 09-19-2009, 11:07 AM
Re: Philco 40-84 case - by rjm - 09-19-2009, 11:53 AM
Re: Philco 40-84 case - by jayoungs - 09-21-2009, 09:48 AM
Re: Philco 40-84 case - by rjm - 09-21-2009, 12:13 PM
Re: Philco 40-84 case - by codefox1 - 09-21-2009, 04:59 PM
There are currently 5534 online users. [Complete List]
» 2 Member(s) | 5532 Guest(s)
