Which Philco model is this?
Thanks for the confirmation Ron!
I found listing for this listed locally for $100 - but it's been a while since it was listed. Hopefully will hear back from the seller. Icon_smile
RE: Which Philco model is this? - by KCMike - 11-03-2016, 09:23 PM
RE: Which Philco model is this? - by Ron Ramirez - 11-04-2016, 05:59 AM
RE: Which Philco model is this? - by Nathan Slingerland - 11-04-2016, 12:08 PM
RE: Which Philco model is this? - by Ron Ramirez - 11-04-2016, 02:57 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
