Philco 46-1209
Anyone have any clue if the resistance readings on the Power transformer are OK... They are reading about 3 times less than the schematic says..
Do not really want to do anymore work on this if Transformer is bad..
Do not want to power it up because the rest of radio is unknown..
Do you think these are in the ballpark or way off..
Skip...
Philco 46-1209 - by vecher - 10-31-2016, 09:41 PM
RE: Philco 46-1209 - by Arran - 11-01-2016, 05:57 AM
RE: Philco 46-1209 - by vecher - 11-01-2016, 02:21 PM
RE: Philco 46-1209 - by morzh - 11-01-2016, 03:33 PM
RE: Philco 46-1209 - by vecher - 11-01-2016, 08:35 PM
RE: Philco 46-1209 - by vecher - 11-02-2016, 03:59 PM
RE: Philco 46-1209 - by Radioroslyn - 11-02-2016, 05:20 PM
RE: Philco 46-1209 - by Kenneth F. Besso Jr. - 11-02-2016, 07:56 PM
RE: Philco 46-1209 - by Paul Philco322 - 11-02-2016, 08:02 PM
RE: Philco 46-1209 - by vecher - 11-02-2016, 11:41 PM
RE: Philco 46-1209 - by Kestas - 11-03-2016, 10:21 AM
RE: Philco 46-1209 - by vecher - 11-03-2016, 10:30 AM
RE: Philco 46-1209 - by vecher - 11-03-2016, 11:22 AM
RE: Philco 46-1209 - by vecher - 11-04-2016, 03:10 PM
RE: Philco 46-1209 - by Arran - 11-05-2016, 05:14 AM
RE: Philco 46-1209 - by vecher - 11-05-2016, 10:12 AM
RE: Philco 46-1209 - by vecher - 11-05-2016, 06:34 PM
RE: Philco 46-1209 - by Radioroslyn - 11-05-2016, 07:37 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 06:42 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 09:08 PM
RE: Philco 46-1209 - by Radioroslyn - 11-05-2016, 10:35 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 11:53 PM
RE: Philco 46-1209 - by klondike98 - 11-06-2016, 08:41 AM
RE: Philco 46-1209 - by vecher - 11-06-2016, 10:22 AM
RE: Philco 46-1209 - by klondike98 - 11-06-2016, 12:23 PM
RE: Philco 46-1209 - by vecher - 11-06-2016, 12:42 PM
RE: Philco 46-1209 - by vecher - 11-10-2016, 06:09 PM
RE: Philco 46-1209 - by KCMike - 11-10-2016, 06:16 PM
RE: Philco 46-1209 - by Nathan Slingerland - 11-10-2016, 06:16 PM
RE: Philco 46-1209 - by vecher - 11-10-2016, 10:33 PM
RE: Philco 46-1209 - by Radioroslyn - 11-10-2016, 11:28 PM
RE: Philco 46-1209 - by Kestas - 11-11-2016, 12:39 PM
RE: Philco 46-1209 - by vecher - 11-12-2016, 08:47 PM
RE: Philco 46-1209 - by vecher - 11-14-2016, 10:33 PM
RE: Philco 46-1209 - by Radioroslyn - 11-15-2016, 01:09 AM
RE: Philco 46-1209 - by vecher - 11-15-2016, 01:13 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5973 online users. [Complete List]
» 4 Member(s) | 5969 Guest(s)
AvatarAvatarAvatarAvatar
