Philco 59c tube substitutions?
Maybe I'll look for some 77s. I would have to assume the 6C6 tubes worked at some point or they wouldn't be in there, but getting some 77s makes more sense.
I also see that the Ryder's has a mistake on it for the filter circuit hookup to the field coil and output transformer.
Charlie in San Antonio
Philco 59c tube substitutions? - by ccomer1955 - 11-04-2016, 10:48 PM
RE: Philco 59c tube substitutions? - by Arran - 11-05-2016, 05:09 AM
RE: Philco 59c tube substitutions? - by Arran - 11-06-2016, 03:48 AM
RE: Philco 59c tube substitutions? - by ccomer1955 - 11-05-2016, 10:30 AM
RE: Philco 59c tube substitutions? - by morzh - 11-25-2016, 12:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5117 online users. [Complete List]
» 2 Member(s) | 5115 Guest(s)
