philco tropic model 42-760
Threads: 2
City: marystown nl canada
(11-05-2016, 06:24 PM)sam Wrote: welcome picker
I don`t have a tropic
but looks like their are only two #72 is a 40 and #74 is a 15
best to try and post schematic this way every one can help
sam I thought that too but it has wires attached to two different pins on its base and I do not know how to post schematic but it can be found on nostalgia air
RE: philco tropic model 42-760 - by the picker - 11-05-2016, 06:32 PM
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
I forgot how the pointer is formed: could you show the way it is formed and how you tried to change it?morzh — 07:01 PM |
Was that pole piece left handed ?
Since the metal "spider" is toast, wonder if you can either get the "4...MrFixr55 — 06:54 PM |
There are currently 4330 online users. [Complete List] » 3 Member(s) | 4327 Guest(s)
