Philco 46-1209
Terry, Ok thanks I let it run for a while.. Transformer cool..
So I assume all is OK.. So on to replacing the Caps. and rebuilding the Backlite block.. I have never done that before so should be interesting.. I need to get some caps for that though..
Skip..
Philco 46-1209 - by vecher - 10-31-2016, 09:41 PM
RE: Philco 46-1209 - by Arran - 11-01-2016, 05:57 AM
RE: Philco 46-1209 - by vecher - 11-01-2016, 02:21 PM
RE: Philco 46-1209 - by morzh - 11-01-2016, 03:33 PM
RE: Philco 46-1209 - by vecher - 11-01-2016, 08:35 PM
RE: Philco 46-1209 - by vecher - 11-02-2016, 03:59 PM
RE: Philco 46-1209 - by Radioroslyn - 11-02-2016, 05:20 PM
RE: Philco 46-1209 - by Kenneth F. Besso Jr. - 11-02-2016, 07:56 PM
RE: Philco 46-1209 - by Paul Philco322 - 11-02-2016, 08:02 PM
RE: Philco 46-1209 - by vecher - 11-02-2016, 11:41 PM
RE: Philco 46-1209 - by Kestas - 11-03-2016, 10:21 AM
RE: Philco 46-1209 - by vecher - 11-03-2016, 10:30 AM
RE: Philco 46-1209 - by vecher - 11-03-2016, 11:22 AM
RE: Philco 46-1209 - by vecher - 11-04-2016, 03:10 PM
RE: Philco 46-1209 - by Arran - 11-05-2016, 05:14 AM
RE: Philco 46-1209 - by vecher - 11-05-2016, 10:12 AM
RE: Philco 46-1209 - by vecher - 11-05-2016, 06:34 PM
RE: Philco 46-1209 - by Radioroslyn - 11-05-2016, 07:37 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 06:42 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 09:08 PM
RE: Philco 46-1209 - by Radioroslyn - 11-05-2016, 10:35 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 11:53 PM
RE: Philco 46-1209 - by klondike98 - 11-06-2016, 08:41 AM
RE: Philco 46-1209 - by vecher - 11-06-2016, 10:22 AM
RE: Philco 46-1209 - by klondike98 - 11-06-2016, 12:23 PM
RE: Philco 46-1209 - by vecher - 11-06-2016, 12:42 PM
RE: Philco 46-1209 - by vecher - 11-10-2016, 06:09 PM
RE: Philco 46-1209 - by KCMike - 11-10-2016, 06:16 PM
RE: Philco 46-1209 - by Nathan Slingerland - 11-10-2016, 06:16 PM
RE: Philco 46-1209 - by vecher - 11-10-2016, 10:33 PM
RE: Philco 46-1209 - by Radioroslyn - 11-10-2016, 11:28 PM
RE: Philco 46-1209 - by Kestas - 11-11-2016, 12:39 PM
RE: Philco 46-1209 - by vecher - 11-12-2016, 08:47 PM
RE: Philco 46-1209 - by vecher - 11-14-2016, 10:33 PM
RE: Philco 46-1209 - by Radioroslyn - 11-15-2016, 01:09 AM
RE: Philco 46-1209 - by vecher - 11-15-2016, 01:13 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4110 online users. [Complete List]
» 3 Member(s) | 4107 Guest(s)
