philco tropic model 42-760
Threads: 2
City: marystown nl canada
the wire with the white clip comes from the small transformer the other wire from that side of the transformer goes to pin 2 of both 42 tubes and the other two wires from the other side of the transformer goes to terminal lugs that connect to the blk and wht speaker wires
RE: philco tropic model 42-760 - by the picker - 11-09-2016, 06:07 AM
1 - 0v - correct
2 - 0v - correct
3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being ope...morzh — 05:15 PM |
I'm going to get back into it tonight. but I disconnected the 2 main resistors off this supply going to different parts ...TV MAN — 04:04 PM |
1 - 0v
2 - 0v
3 - 0v
4 - 12v
5 - 0v
6 - 11.9v
7 - 12v
8 - 12v
9 - 12v...R3Sons — 02:09 PM |
What is "everything else?"
Quick progress report:
There are currently 3540 online users. [Complete List] » 2 Member(s) | 3538 Guest(s)
