Philco Mic? Speaker? Model Number?
I can't say for sure but found this one that's similar.
http://www.ebay.com/itm/Vtg-1930s-PHILCO...SwknJX0ukR
RE: Philco Mic? Speaker? Model Number? - by KCMike - 11-09-2016, 05:55 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
