1929 Northland TRF with Shortwave and the B-1B Bomber
Icon_thumbup
Yes, it was fun tracking him down too.
RE: 1929 Northland TRF with Shortwave - by KCMike - 11-09-2016, 04:59 PM
RE: 1929 Northland TRF with Shortwave - by morzh - 11-09-2016, 05:09 PM
RE: 1929 Northland TRF with Shortwave - by klondike98 - 11-09-2016, 10:37 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3844 online users. [Complete List]
» 1 Member(s) | 3843 Guest(s)
