Philco 46-1209
Ok, Found 2 more problems.. The Volume control and the Tone control.. But after a good cleaning they seem to be working correctly now..
Still waiting on my order from Just radios. But looks like now my stock of .01 Caps are low. This radio has about 8 .01's in it and I only have 4 left.. So now I have to order more..But I have to order 20.00 worth due to the min order requirements.. What a PITA.,...
Oh and this radio has some .006 Caps in it.. What value do you use for those.. Are .0047 's OK for that??
It seems that it always something..
Well enough complaining..
Skip...
Philco 46-1209 - by vecher - 10-31-2016, 09:41 PM
RE: Philco 46-1209 - by Arran - 11-01-2016, 05:57 AM
RE: Philco 46-1209 - by vecher - 11-01-2016, 02:21 PM
RE: Philco 46-1209 - by morzh - 11-01-2016, 03:33 PM
RE: Philco 46-1209 - by vecher - 11-01-2016, 08:35 PM
RE: Philco 46-1209 - by vecher - 11-02-2016, 03:59 PM
RE: Philco 46-1209 - by Radioroslyn - 11-02-2016, 05:20 PM
RE: Philco 46-1209 - by Kenneth F. Besso Jr. - 11-02-2016, 07:56 PM
RE: Philco 46-1209 - by Paul Philco322 - 11-02-2016, 08:02 PM
RE: Philco 46-1209 - by vecher - 11-02-2016, 11:41 PM
RE: Philco 46-1209 - by Kestas - 11-03-2016, 10:21 AM
RE: Philco 46-1209 - by vecher - 11-03-2016, 10:30 AM
RE: Philco 46-1209 - by vecher - 11-03-2016, 11:22 AM
RE: Philco 46-1209 - by vecher - 11-04-2016, 03:10 PM
RE: Philco 46-1209 - by Arran - 11-05-2016, 05:14 AM
RE: Philco 46-1209 - by vecher - 11-05-2016, 10:12 AM
RE: Philco 46-1209 - by vecher - 11-05-2016, 06:34 PM
RE: Philco 46-1209 - by Radioroslyn - 11-05-2016, 07:37 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 06:42 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 09:08 PM
RE: Philco 46-1209 - by Radioroslyn - 11-05-2016, 10:35 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 11:53 PM
RE: Philco 46-1209 - by klondike98 - 11-06-2016, 08:41 AM
RE: Philco 46-1209 - by vecher - 11-06-2016, 10:22 AM
RE: Philco 46-1209 - by klondike98 - 11-06-2016, 12:23 PM
RE: Philco 46-1209 - by vecher - 11-06-2016, 12:42 PM
RE: Philco 46-1209 - by vecher - 11-10-2016, 06:09 PM
RE: Philco 46-1209 - by KCMike - 11-10-2016, 06:16 PM
RE: Philco 46-1209 - by Nathan Slingerland - 11-10-2016, 06:16 PM
RE: Philco 46-1209 - by vecher - 11-10-2016, 10:33 PM
RE: Philco 46-1209 - by Radioroslyn - 11-10-2016, 11:28 PM
RE: Philco 46-1209 - by Kestas - 11-11-2016, 12:39 PM
RE: Philco 46-1209 - by vecher - 11-12-2016, 08:47 PM
RE: Philco 46-1209 - by vecher - 11-14-2016, 10:33 PM
RE: Philco 46-1209 - by Radioroslyn - 11-15-2016, 01:09 AM
RE: Philco 46-1209 - by vecher - 11-15-2016, 01:13 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8199 online users. [Complete List]
» 3 Member(s) | 8196 Guest(s)
