Philco 51-532 transitone squeaks, hums, and crackles (a little bit)
Hey Charlie,
I knew you could do it!! I started to post a reply a couple of hours ago but got a phone call and distracted. Ant loop must be connected properly for the set to work.
Using the 33mf caps are  fine.
RE: Philco 51-532 transitone squeaks, hums, and crackles (a little bit) - by Radioroslyn - 11-10-2016, 10:24 PM
Restoring Philco 96
There are currently 7598 online users. [Complete List]
» 3 Member(s) | 7595 Guest(s)
