Hum in Philco 16B
Something I've done on hi gain homebrew stuff is rectify the filament voltage. Just a simple half wave and a big cap. If you can do it near the pt it will eliminate ac radiation of the filament wiring. I realize this isn't quite what you're looking for but may give you some insight to what is the real issue. Something else how about the line bypass caps, if you remove those does it change things? Or replacing the 1st audio tube?
Hum in Philco 16B - by morzh - 11-11-2016, 01:07 PM
RE: Hum in Philco 16B - by Kenneth F. Besso Jr. - 11-11-2016, 01:45 PM
RE: Hum in Philco 16B - by Radioroslyn - 11-11-2016, 02:06 PM
RE: Hum in Philco 16B - by morzh - 11-11-2016, 02:18 PM
RE: Hum in Philco 16B - by Nathan Slingerland - 11-11-2016, 02:42 PM
RE: Hum in Philco 16B - by morzh - 11-11-2016, 04:45 PM
RE: Hum in Philco 16B - by Radioroslyn - 11-11-2016, 05:28 PM
RE: Hum in Philco 16B - by morzh - 11-11-2016, 08:35 PM
RE: Hum in Philco 16B - by Kenneth F. Besso Jr. - 11-12-2016, 11:49 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5218 online users. [Complete List]
» 2 Member(s) | 5216 Guest(s)
