Threads: 271
City: Wilsonville
State, Province, Country: OR
This set may be tough to get running. I've been going through it to measure coils and see where various components are and it appears the secondary of the first IF coil is open ![Icon_sad Icon_sad](https://philcoradio.com/phorum/images/smilies/icon_sad.gif) . If I recall correctly the accuracy in rewinding the secondary is much more critical that rewinding the primary. It will take some work to get this coil apart and see if the break is easily fixed or not.
[Image: https://www.dropbox.com/s/tloh8w3swjn5ls....jpg?raw=1]
[Image: https://www.dropbox.com/s/m4xg3uuhbfoe0g....jpg?raw=1]
RE: Emerson 350 aw - by klondike98 - 11-11-2016, 04:09 PM
Users browsing this thread: 17 Guest(s)
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
