Hum in Philco 16B
Nope did not guess it Icon_smile
Plus have none in the basement and cannot make the whole family to stop using computers or watching TV.
FOUND IT!
While checking the grounding bolts on backelite block and measuring them to GND I found missing connection in the backelite holding the Y-caps of the MAINS filter. The reason: they used this for the solder post to bring one of the power wires in and connect to the power transformer. The post has insulating base effectively isolating the bolt from the block's power lug, so the 10nF caps have no center GND point.
After that the hum went WAY down. A little remains but no worse than the rest of my radios. And this is when plugged through the isolation transformer; when plugged into the outlet straight, no hum.
Terry, remember the discussion about these caps one day here? Well....they do matter Icon_smile
Hum in Philco 16B - by morzh - 11-11-2016, 01:07 PM
RE: Hum in Philco 16B - by Kenneth F. Besso Jr. - 11-11-2016, 01:45 PM
RE: Hum in Philco 16B - by Radioroslyn - 11-11-2016, 02:06 PM
RE: Hum in Philco 16B - by morzh - 11-11-2016, 02:18 PM
RE: Hum in Philco 16B - by Nathan Slingerland - 11-11-2016, 02:42 PM
RE: Hum in Philco 16B - by morzh - 11-11-2016, 04:45 PM
RE: Hum in Philco 16B - by Radioroslyn - 11-11-2016, 05:28 PM
RE: Hum in Philco 16B - by morzh - 11-11-2016, 08:35 PM
RE: Hum in Philco 16B - by Kenneth F. Besso Jr. - 11-12-2016, 11:49 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4190 online users. [Complete List]
» 3 Member(s) | 4187 Guest(s)
