Philco 46-1209
#33
Thanks, Some parts arrived today.. My caps for them AC line and some resistors I needed.. So back to the replacement of caps and resistors..Then on to the volume control and tone control .. They seemed not to be working correctly so I need to check again
Skip...
Philco 46-1209 - by vecher - 10-31-2016, 09:41 PM
RE: Philco 46-1209 - by Arran - 11-01-2016, 05:57 AM
RE: Philco 46-1209 - by vecher - 11-01-2016, 02:21 PM
RE: Philco 46-1209 - by morzh - 11-01-2016, 03:33 PM
RE: Philco 46-1209 - by vecher - 11-01-2016, 08:35 PM
RE: Philco 46-1209 - by vecher - 11-02-2016, 03:59 PM
RE: Philco 46-1209 - by Radioroslyn - 11-02-2016, 05:20 PM
RE: Philco 46-1209 - by Kenneth F. Besso Jr. - 11-02-2016, 07:56 PM
RE: Philco 46-1209 - by Paul Philco322 - 11-02-2016, 08:02 PM
RE: Philco 46-1209 - by vecher - 11-02-2016, 11:41 PM
RE: Philco 46-1209 - by Kestas - 11-03-2016, 10:21 AM
RE: Philco 46-1209 - by vecher - 11-03-2016, 10:30 AM
RE: Philco 46-1209 - by vecher - 11-03-2016, 11:22 AM
RE: Philco 46-1209 - by vecher - 11-04-2016, 03:10 PM
RE: Philco 46-1209 - by Arran - 11-05-2016, 05:14 AM
RE: Philco 46-1209 - by vecher - 11-05-2016, 10:12 AM
RE: Philco 46-1209 - by vecher - 11-05-2016, 06:34 PM
RE: Philco 46-1209 - by Radioroslyn - 11-05-2016, 07:37 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 06:42 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 09:08 PM
RE: Philco 46-1209 - by Radioroslyn - 11-05-2016, 10:35 PM
RE: Philco 46-1209 - by vecher - 11-05-2016, 11:53 PM
RE: Philco 46-1209 - by klondike98 - 11-06-2016, 08:41 AM
RE: Philco 46-1209 - by vecher - 11-06-2016, 10:22 AM
RE: Philco 46-1209 - by klondike98 - 11-06-2016, 12:23 PM
RE: Philco 46-1209 - by vecher - 11-06-2016, 12:42 PM
RE: Philco 46-1209 - by vecher - 11-10-2016, 06:09 PM
RE: Philco 46-1209 - by KCMike - 11-10-2016, 06:16 PM
RE: Philco 46-1209 - by Nathan Slingerland - 11-10-2016, 06:16 PM
RE: Philco 46-1209 - by vecher - 11-10-2016, 10:33 PM
RE: Philco 46-1209 - by Radioroslyn - 11-10-2016, 11:28 PM
RE: Philco 46-1209 - by Kestas - 11-11-2016, 12:39 PM
RE: Philco 46-1209 - by vecher - 11-12-2016, 08:47 PM
RE: Philco 46-1209 - by vecher - 11-14-2016, 10:33 PM
RE: Philco 46-1209 - by Radioroslyn - 11-15-2016, 01:09 AM
RE: Philco 46-1209 - by vecher - 11-15-2016, 01:13 AM
Users browsing this thread: 13 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 9165 online users. [Complete List]
» 3 Member(s) | 9162 Guest(s)
