Transformer 32-8341 info needed
Do you happen to know what it was used in or for?? Pic ??
Transformer 32-8341 info needed - by Conelrad - 11-13-2016, 11:28 PM
RE: Transformer 32-8341 info needed - by Radioroslyn - 11-14-2016, 08:15 AM
RE: Transformer 32-8341 info needed - by Conelrad - 11-14-2016, 08:29 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4761 online users. [Complete List]
» 2 Member(s) | 4759 Guest(s)
