Philco 71....I went and did it !!
The "Clyde Shuler" style Philco cabinets use a quarter cut mahogany in an inverted "V" match.
First, let me say, I'm not one to take the easy way. If I were going to patch the veneer, I would make a cut parallel with the grain, just below the "sand through" and replace the veneer all the way up to the match line at the top of the arch.  If I didn't like the results, I reveneer the whole arch.
M R Radios   C M Tubes
Philco 71....I went and did it !! - by wbaradio - 11-08-2016, 08:58 PM
RE: Philco 71....I went and did it !! - by KCMike - 11-09-2016, 07:58 PM
RE: Philco 71....I went and did it !! - by Arran - 11-14-2016, 06:30 AM
RE: Philco 71....I went and did it !! - by Steve Davis - 11-14-2016, 07:53 PM
