Philco 40-84 case
Well I have tried soap and water, Polish and even brasso and no luck. I am thinking whatever they used to coat it is what's changing the color to look like its dirty.
Any other suggestions?
Has anyone come across this? Any help would be appreciated.
Richard
Philco 40-84 case - by rjm - 09-05-2009, 05:20 PM
Re: Philco 40-84 case - by exray - 09-05-2009, 10:47 PM
Re: Philco 40-84 case - by rjm - 09-05-2009, 11:09 PM
Re: Philco 40-84 case - by exray - 09-06-2009, 12:24 AM
Re: Philco 40-84 case - by rjm - 09-17-2009, 05:09 PM
Re: Philco 40-84 case - by jayoungs - 09-18-2009, 04:14 PM
Re: Philco 40-84 case - by rjm - 09-18-2009, 04:47 PM
Re: Philco 40-84 case - by codefox1 - 09-19-2009, 11:07 AM
Re: Philco 40-84 case - by rjm - 09-19-2009, 11:53 AM
Re: Philco 40-84 case - by jayoungs - 09-21-2009, 09:48 AM
Re: Philco 40-84 case - by rjm - 09-21-2009, 12:13 PM
Re: Philco 40-84 case - by codefox1 - 09-21-2009, 04:59 PM
Philco 91 Tuning Condenser
There are currently 10195 online users. [Complete List]
» 3 Member(s) | 10192 Guest(s)
